1 - 8 of 8 Posts
· W163 and General M Gremlin
goof-off works.
Heat gun.
I would have mentioned earlier, heat gun, but there are defrost wires in place.
very Mindful use of a heat gun, in this area, otherwise....
don't ask me how I know.
repair of the heating wire, is doable though, but you really don't want to go there.
Reactions: wlb50 and Dikdaan
1998 W210 E320 (current) 2001 ML320 (prior)
Discussion Starter · #7 ·
Thanks guys. I got the sticker off. Heat gun and plastic scraper did the whiter uncooked part of the sticker. The black cooked part was kind of welded on. I used a razor blade to work it off avoiding the lines of the defroster grid. Remaining adhesive came off with goof off or goo gone or whatever is the sticky yellow liquid stuff.
1999 E430 Sport
Good job. For the next guy, Naphta spirits will dissolve glue residue and not harm substrate. Defrost elements should be fine. I use this stuff to clean up collectables. It is safe on wood veneer, clean plastic, and a lot more.
1 - 8 of 8 Posts
