My horn and turn signals have quit working and we are thinking that the ground on the horn ring maybe be broken. Do I access this by removing the the horn cover . I can get the sides loose but i am afraid to pull the center loose. Any suggestions. This is on a 82 300CD. PS the fuse and the flasher have been changed and all of the other lights work fine. Neither turn signal works
· BenzWorld W126 & W201 Host
1988 420SE, 2002 C180 Kompressor, 200 ML320
Horn, Indicators
Billy
Read the same problem recently on this forum but i can't find it now.
The solution posted on that one was that there is an earth on the steering columb that should be checked.
I assume it worked because the person who posted it never came back to say it didn't.
[:I]
· Always Remembered RIP
If I remember correctly there may be some kind of clip were I used a small screwdriver t...
If I remember correctly there may be some kind of clip were I used a small screwdriver to undo. Your best bet would be to ask your local dealer or phone a main Mercedes Technical Centre (your local dealer should give you the number, if they can't help you).
Sorry I couldn't be of more help but it was a long time ago.[8)]
The number for the UK is 01908 245000, very helpful lot.[:)]
If you are just trying to remove the rubber center cover from the wheel, just yank it of...
If you are just trying to remove the rubber center cover from the wheel, just yank it off ! ! ! !
