1 - 8 of 8 Posts
1984 Mercedes-Benz 300DT; 1980 Mercedes-Benz 300SD
I need to access power from the fuse box, there's a 8mm nut I removed, but I still can't get the fuse box to budge, I want to run a wire through the firewall to my dash, for a switch, is there something I'm missing?
torkq
1978 280ce euro found dead on Ebay
I just ran a wire to my dash for my tach install. I used one of the extra opennings where the vacumn hoses go through the firewall worked great.
I need to get power from the fuse box though, so I need to run it through it, so its not being crimped down by the fuse box cover
1982 300TDT 150,000 miles 1985 380SE 130,000 miles 1991 560SEL 81,000 miles (a/k/a the nightmare)
There's info on it here if you sift through it... and while you're at it, you could always set up your lights to run as Euro Spec would (without, of course, the actual lighting element upgrade)...
Mercedes Benz W123 Headlight Upgrade
Discussion Starter · #5 ·
thanks to loss,
Thats what I remember doing, its just one 8mm nut, but for some reason its not moving, I'll go give it another try...
Be very gentle... all those wires tied into the box and the years will make for some stiffness encountered when trying to move it. Also, there are some little clips toward the bottom of the panel that slide over the sheet metal towards the interior of the engine compartment that serve to help hold the panel in place...
Discussion Starter · #8 ·
Ok, it wasn't to difficult to pop it in (towards the kick-panel), so I did what I had to do.
The biggest headache of it all was pulling/putting it back in, had to use the two knobs that close up the fuse box cover to help guide it in, but its definately a "take your time" kind of thing, you dont want to break any of the plastic pieces, or break the screw that holds the fuse box in place. Its really just pressured in place.
1 - 8 of 8 Posts
