93 190E 2.6; 82 300 SD Turbo
you dont even need a diagram to get it out, its very very easy...
feel around the front of the bottom cushion somewhat near the door for a spring-loaded lever, (there are 2 of these one on each side of the car) pull those levers and lift the seat upwards, then pull forwards and the bottom is out. There are 3 (i think 10mm) screws, 1 is direcly under the armrest area. the remaining 2 are on the sides near the doors. Take out those 3 then push the back cushion upwords, there are 5 metal things that go into brackets, these will come out as u lift upwards. To install it, proceeed backwards, the hard part is getting all 5 of those clips in.
Hope this helps
Kris
