I was trying to remove my hardtop and couldn't get it off. I undid the bolts in front and back push the lever. But, it would only come up about 1-2 inches in the back. It was like it was caught. What was I doing wrong. Thanks
hello RadioTekIt takes at least one more person to help, preferably strong, so SWMBO is usually not an option. What has happened is that the big pin in back is still hooked into the latch mechanism. The easiest way is to get another person and rotate the top to the side about 10 to 20 degrees to get the latching mechanism out of the notch on the pin. Of course, you have to have all the other attachment points loose (top of windshield, behind seats, defroster cable) It's a little bit tricky, but if you're gentle and careful, it should pop right off.
The other accepted option is to get between the body and the top with a long, slim jawed vice-grip on the pin, and turn it, getting the latch hook out of the pin notch. This would leave some marks on the pin, and be a bit more difficult, with the possibility of scratching paint if not very careful.
Good Luck,
Scott
Your image did not attach. Here is a thread showing a few pictures and some ways to adjust the cable: http://www.benzworld.org/forums/r-c107-sl-slc-class/1595954-adjusting-top-lock-rear-peg-so.htmlI have read the posts on releasing a balky top latch with coat hangers, etc. It would seem that the small release lever operates by pivoting the latch post through a sheathed cable. Maybe the cable has a swaged end fitting that is slipping. The mechanism has 3 nuts that hold it onto the trunk bulkhead. Is it repairable? See the attached image.
/Users/williamgraham/Desktop/Mercedes Bow Capture Mechanism.JPG
WGraham
Member
I personally can't see "rotating" it with less than 3 people, one on each rear corner and one on the front! Of course I am a wuss...He tried it alone!
