201 - 216 of 216 Posts
1983 380 SL
Discussion Starter #201
Anybody have any suggestions on the best assembly lube to use on a 116.962 engine? I've been using Permatex Ultra-Slick Engine Assembly Lube but nothing feels like it's moving freely. The cams are especially stiff and don't turn easily in the towers even without any valves installed. It's not that they don't turn smoothly, they do, it's just that there is a lot more resistance to turning then I would have expected.
1998 C280; 1987 560SL
Out of curiosity - how did check clearances with the cam bearings? I am hardly an expert at such, but the mechanics I used to work with on turbomachinery used plastigage to check clearances. Two things come to mind that might make the cams hard to turn - 1) clearance too tight or 2) cam tower misalignment. Not sure how you check that the cam towers are aligned?
1983 380 SL
Discussion Starter #203
The cam towers have location pins, no adjustment required or even possible. Also, there are no cam bearings. The Towers are aluminum which I assume were line bored with the cam towers in place on the head. I returned every cam tower to it's original location.
I'm guessing that the assembly lube is so thick (way thicker than oil) and the clearances are so tight that it's the assembly lube itself that is making the cam so hard to turn. It requires enough force to get it to turn that it's close to painful to be turning it by grabbing the cam sprocket. I wouldn't go so far as to say it's actually painful but you certainly are aware you've got a sprocket with teeth in your hand.
Lets put it this way... no matter how fast I try to turn the cam by the cam sprocket, it stops immediately as so as I let go. It takes considerable force to turn the cam by the cam sprocket. If that's normal when using assembly lube then fine... I've just never encountered it before. It may be that Permatex assembly lube is just too thick... more like grease than oil.
1984 380 SL
Hi,
just briefly looking at specs you have something like .025 clearance bet the camshaft and bearing, if it was to loose you would loose all your oil pressure when running as it would just flood through the towers,
here in the uk the engine build grease I use has the constistancy like a single/ light cream that you would put on your food!! If it was me I would remove the camshaft clean off all the grease then coat / smear all the journals/tower with engine oil and then just test it that way by hand. The grease is designed to stay there until the oil pump has had a fair chance to get the oil flowing around the system.
my thoughts anyway.. good luck
1983 380 SL
Discussion Starter #205
Hi,
Excellent suggestion... I'll try it.
1983 380 SL
Discussion Starter #206
Removed the cams and cleaned off the assembly lube... put the cams back using motor oil instead of assembly lube and the difference is like night and day. The cams spin much freer now.
Thanks for the suggestion.
1985 280SL
As long as you're going to fire it ASAP, motor oil is fine. It will mostly drip off if you leave the engine sitting for awhile. That's why assembly lube is thick - it stays put.
I only use assembly lube when I don't know for sure when the engine will be fired. If it's going to be in the next few days after assembly, I use engine oil.
1989 560SL
I always used a product from GM called EOS (Engine Oil Supplement) which is also thick and gooey but certainly eliminates a dry start.
The other thing I did was leave the spark plugs out, disable the fuel pump and then crank the engine until I had oil pressure.
Sent from my iPad using Tapatalk
1987 560 SL, 1990 300E 4Matic
I'll bet you breathed a sigh of relief.
1983 380 SL
Discussion Starter #211
Figured I give you guys an update. I ordered and received the new main bearings and rod bearings but I haven't ordered the rings or gasket sets yet (4 kids worth of college loan payments can put a real dent in your mad money). I also have yet to find a good source for the drill template for the TimeSerts, nor have I ordered the TimeSerts yet.
Roncallo stopped by a few weeks (a month?) ago when he was visiting Long Island and we spent a few very pleasant hours talking shop over a couple of beers. I asked him a question (well, more than one) but on one of them he suggested I post it here because he didn't know the answer. So here it goes...
On the cams there is a large washer that goes on the front end of the cam just forward of the first cam tower. This washer has the timing mark on it (see red arrow pointing to the right) and the cam tower itself has the corrosponding timing mark (see the red arrow pointing up). The cam itself and the sprocket have locator notches for the Woodruff key and so does the large washer that has the timing mark. The problem is that large washer has 2 notches for the Woodruff key 180 degrees apart from each other. The question is... how do I know which notch to use? Anybody know?
560SL '88 Suzuki GS1000E '78
Hi Jyuma, this evening I will check my photo collection and maybe I can give you a feedback.
To do it like the scientists: Turn the crankshaft to 0° TDC cyl. 1. Taking the firing order, you can assign the cam position. For the first cylinder it’s very easy, because it’s perfect detectable. There both cams must be orientated in maximum rotary position away from the contact-point of the rocker. In this orientation the cam is in “TDC”-position for this side and cylinder. If not, turn the camshaft for 180°.
Now turn the crankshaft 90° (cw) so the 5. cylinder who is the next in TDC and firing-order reaches it's TDC, here you may have the same. The both cams (ex and in) need be located in maximum rotary position away. If not, turn the cam for about 180°.
Firing order M117:
Martin
Edit: 720/8=90 I edited the number reagarding "...Now turn the crankshaft 90° (cw) so the 5. cylinder...".
1985 380 SL
See below - is this what you are looking for?
2620085
1983 380 SL
Discussion Starter #214
Firing order M117:
Martin
Thank you for your response but the engine and heads are totally dismantled (empty block, no valves in heads) due to the fact that I'm doing a total rebuild of the engine. When I put it all back together I'll follow your guidelines. Thank you.
1983 380 SL
Discussion Starter #215
Now that makes it easy for assembly when the engine is just an empty block and the heads don't even have the cams installed. I knew there had to be a way to determine which way the washer went on but I never noticed or knew that the grove under the timing the mark is the one to use. Curious that they bothered to put two notches in the washer, there must be a reason.
Thanks you (y)
Outstanding Contributor
450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro
1-5-4-8-6-3-7-2. So Cyl 6 is 180 degrees off cyl 1. So I’d expect TDC, closed valves, bunny ears on cyl 1 to be 180 cam degrees off from cyl 6. Since you’ve only got two options, just make sure you aren’t “bunny ears” on cyl 6.
