Hello All , i have a new problem.
i don't understand how to remove the front bumper:( ?
i want to replace the motor of wiper front ligth and i suppose it's necessary to remove the front bumper no ?
thank you for your help :bowdown:
No, you just have to remove the valence under the headlight, IIRC.
Take off the blinker (loosen big white plastic screw towards engine compartment and slide out), it becomes obvious from there - one Phillips screw towards the grill and a 10mm nut on the outside and you're done.
If you still want to take off the bumper...that's four nuts on each side, forgot the size - 13mm, maybe?
