1996 Benz S500 Coupe
Good day all,
Need help with removal of my windshield sprays from hood, I'm a proud owner of a 1996 S500 2dr Coupe. Replacing the hood and not sure how to remove spray devices for windshield. Any help will be greatly appreciated.
Thanks a bunch,
jfeels:surrender:
92 500SEL to 01 E320T current 2014 lexus LS460
You will notice two plastic retainers, if you get a little hook you can pull them out, the pins on the nozzles will be able to be collapsed and the assembly will come out of the hood. There is a hose and a wire attached, water and heat.
Thanks Peter, i have all 3 popped out. do i take the hoses unplugged so i can remove components from the hood. Or whats the best way to get them out of old hood for new?
Peter, was able to pull the nozzles loose and retrieve the entire hose from the hood.
Thanks very much,
jfeels
Great, I had clogged nozzles, and it took time to figure out how they were in there. I finally pushed the pins thru and was able to retrieve them. I would clean them as long as they are out. You can adjust them using a needle or a map pin, I like the map pin.
I cant belive MB has a tool to remove the plastic retainers.
