1 - 13 of 13 Posts
Hi folks,
What is involved in removing the "knee pad" or knee bumper area right under the steering column? I'm 6'2" and like to lean back to get some arm room but my knees bang on the padded area right below the column. I'd like to remove it to see if that helps, but I'm not sure how it comes off. Also, I don't know what that will expose when it's off. Wiring? Anybody know?
Andy
1999 SLK230/ 2006 Passat/ 1995 Bronco (Prerunner)
I removed mine the first weekend I bought the car (in Vegas on a road trip). It is "plastic rivit" type attachment, a kind of melted plastic sticking through small holes in the under dash section. All that will be left are I think 6 small holes about 1/2" or smaller......not noticable at all. I am 6'2" also so I wondered if anyone else had done this.
99 slk230 sport
i did and it was such a great thing. this dumb pad is rediculous. even a 5'6" driver would benefit but for us 6'6" its required! i did drive 1000 miles in two days with it still in however. [xx(]
SLK200 '97 nov
hi there, what is this knee pad thingy? is it only for slk32amg only? or does this apply for all slks?
2001 SLK320, 2001 C320
Look at the bottom of your dash on the driver's side. You'll see a large lump of extra plastic that appears to be stuck on to the lower dash. That's the kneepad.
I'm gonna rip that sucker out one of these days!!! [:(!]
99 slk230 sport
takes 5 min, free, and will make you wonder what the hell they put it there for anyway. i thought i would kep it for resale or in case i have it forever and need those concours points but decided its just worthless so i chucked it!
SLK200 '97 nov
Really? It must be on the models after mine coz I don't have these driver knee pads at all! Is it possible to post a picture? Thanks!!
Discussion Starter · #8 ·
Cool! You guys are giving me hope! So how'd you remove it, just pull on it? No tools required? I don't want to break anything in the process so any instructions would be appreciated.
Thanks!
1999 SLK230 Sport
I think Tungster could tell you how to remove just about anything in the interior[:0][:0]
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1257794&posts=1&fid=26
I'm gonna bump this one to the top, because I want to do it too.
Is it a yank and rip job??? Or does it require somewhat more finesse?
Discussion Starter · #11 ·
I wanna know too, page62. I have a good mind to just get after it, but I'd really like to at least know what to expect when I start hearing ripping and breaking sounds.
99 slk230 sport
just pry the flocker off. it has about 6 rivets that will pull out of the upper moulding. i suggest using a wooden spoon or other pry bar but i just uses me hands. stop lollygagging and just do it boys! [;)]
Discussion Starter · #13 ·
Instant kneeroom!
I took berk's advice and just ripped it off by hand. You will have to break some plastic attachments, so its not just going to fall off in your hands. I cringed a bit when I heard some breaking, but it was harmless. Like berk said, leaves six holes which aren't really noticeable, but that additional legroom sure is! Thanks boys!
1 - 13 of 13 Posts
