1 - 12 of 12 Posts
Hi Guys
Can someone tell me how many catalytic converters does a w203 have?
I drive a 2001 C180 (non kompressor).
Also, if i remove the catalytic converter(s), will this cause the CEL to come on?
I live in a country that does not require (by law) to have a catalytic converter on a vehicle.
This is only a guess but it might mess up your O2 reading (sensor is positioned after the cat)- also wouldn't think it would be worth the trouble?
We'll be keeping the air clean for you anyway!!!!
Oberoi
Thanks Oberoi.
To have it replaced costs about R13,000 about 1,541.58 USD.
The mileage on my car is currently 296000kms :eek: (183925miles)
The catalytic converter is blocked. On start up you can hear it. I have to get it removed.
Fair enough, you can easily see the number of cats if you peer underneath - the attached pics are from my SLK to give you an idea (2 cats on the early models) -it should be similar
Oberoi
if u striaght piping both the cats ur gunna need someone with a laptop or good scanner to reset the values so u dont have the car running rich (higher gas consumption) 100 % of the time...
The up-stream O2 sensors monitor your fuel, the down-stream O2 sensors monitor how the cats are working. By removing the cats, the computer will throw a light because the cats are no longer doing their job.
Forgive me for my ignorance sammy.. what values are you referring to?
Thanks whosdis!
I'm assuming that the CEL will continuously come on because there will be no cats there..
So my next question will be..
How do i fool the ECU into thinking that the cats are still there??
Discussion Starter #12
Okay... so i had the cats removed. The car is sounding a bit louder.. not alot though. Didn't notice any increase in performance.
A cat blocker was used to 'fool' the ecu into thinking that the cat is still there.
Car is going good no CEL lights came on.. as yet :)
1 - 12 of 12 Posts
