1 - 8 of 8 Posts
99 SL 500 - 03 SLK 230 - 90 SEL
Hi, I have a W210 (2000) and I replaced the battery the other day. I reprogrammed all the windows etc. Well I can not get the express feature to work in the sunroof no matter what. I have tried it all. Also The remote window up/down feature is intermittent. Sometimes it works sometimes not. I have a feeling it has something to do with the sunroof. I put a new battery in the remote. Is there something I am missing? Should I disconnect the battery and start over? Very annoying. Anyone have a suggestion or experience with this issue?
Is your sunroof operating OK with the manual switch? Might need resetting?
I found the remote window opening /closing a bit annoying as well. Hard to determinate what makes it working, but most of the time I have to double click it.
Yes works fine, no problem. It is supposed to express open like the side windows ( I think ) and I figure it is effecting the remote close/open feature.
Express open should work if you press the switch past the detent. I didn't think mine was working either until I saw someone here explain that. I was not pressing the switch far enough. Hope the helps.
I read somewhere that the express is available on 2002 up, mine is a 2000. Anyone clarify that?
So is on both of our 1998 models, besides the mentioned annoying button operations.
I think 1997 was cutting year, since this model has no speed function on rear windows.
2007 E320 Bluetec, 2008 320ML CDI
My '98 requires one press on remote, then second press and hold for windows to open along with sunroof. I don't believe the '98's will express open with remote. I notice that if I leave the sunroof tilt-open, the remote open only does the windows.
Remote closing is similar on that I press and hold the lock button until roof is closed and windows up.
Skippy
Sent from phone.
1 - 8 of 8 Posts
