1 - 10 of 10 Posts
2001-W210-CAPRI METALIC BLUE-/ 2002-W210 E300D
Hey forum, yes I am still here and just love this car
I have tried to find a map for all the relays, number and function to no avail.
Any ideas?
B
1998 E320 base sedan @ 160kmiles
Well, you basically have 3 relay and fuse modules. One at the drivers side (where the 38 pin connector is), one at the passenger side (in the module box), and one under the rear seat (has the fuel pump relay only as far as I know).
The relays at the passenger side is inside an enclosed module. You need to remove the black enclosure. The driver's side relays are under the lid closer to the firewall. Do you need the designation list of the relays ?
Thanks for the fast response
the relays in the drivers side under hood with 38 pin fuse box
any chance for a picture or diagram of the location of the relays?
B
Here is a picture. It shows relays with letter designations. What is the problem you are trying to solve ?
sent you a pm
1 - 10 of 10 Posts
