1 - 8 of 8 Posts
Rolled my windows up with the remote yesterday. Pass rear made a snap noise when it.made it all the way up.
some how it went back down when I went back to the car and unlocked.it.
Would not go back up properly it made it back up but with a lot of switch fiddling. It will go down just fine but up it goes up an inch then wimps out. Then nothing at all. Then a millimeter jump. If I wait a few min it would go up again an inch then a millimeter jump etc.
Whatever it is, it's probably time to pop off the door inner liner. My money is on a broken regulator...
Outstanding Contributor Always Remembered RIP
These cars us a cassette as a regulator, and yes door card off job
You do need to check that the glass is not too tight in the rails.
All MB parts are guaranteed for 2 years in the UK anyway
What you most likely have is a bad tooth on the reg! When window gets to the top the gear on the motor skips on the tooth ! I had that on my drivers side when I got the car and I got a OEM reg from Eddie and the thing has worked like new ever since. The install I thought was gonna be a bitch but really went pretty easy thanks to the tips from the guys here!! Eddie gave a good price! cheaper than those pieces of tin from FleBay!!
Smokie
1 - 8 of 8 Posts
