Hi,
I'm in the middle of an A/C job, and I suspect that there is some electrical fault with either the front SAM unit (N10/1) or C-AAC (N22/7). Based on the recorded SAM error (code B1046), it thinks there's either a short or open connection to sensor B12/2 (refrigerant temperature and pressure sensor). Shockingly, live data showed that the refrigerant temperature was 255 Celsius (as read from the SAM) and ~6500 Celsius when read from the A/C module. I'm not sure why the two modules would report different readings for the same sensor, but these are clearly invalid. Though I feel it's possible this is the cause behind the inoperative A/C system, there are also reasons that this may not be the fault:
-Excessive temperature reading would force the engine fan to 100% constantly, which is not the case--the fan runs normally under load.
-Temperature/pressure sensor B12/2 was already replaced when a new condenser was installed, so there shouldn't be any issues with the sensor itself.
-Invalid readings such as these extreme temperatures can just suggest that the vehicle model isn't equipped with the sensor, so my "temperature sensor" could be nonexistent to begin with.
All I can think of now is some kind of faulty connection between the sensor and SAM or C-AAC, perhaps water damage or some kind of miscellaneous engine wear on the connection. I will check the connections at the bottom of the SAM for corrosion, but does anyone know how the b12/2 cable is routed and what it looks like? Other than this, there are no relevant faults that would impede an otherwise working air conditioning system.
Let me know if there is missing information, thank you.
