1 - 11 of 11 Posts
E-Class, SLK
My 2011 E350 comes with a 722.906 transmission. The vehicle was delivered in April 2011 but I can't find information when it was build to determine its transmission fluid is Red or Blue (built after June 2010).
My vehicle is reaching 38K miles and I plan to change the ATF soon but don't want to purchase a wrong type of fluid. I would appreciate for any suggestion.
13 GLK350, 02 325, 94 sonoma, 12 RAM, 01 WS6
good rule of thumb ^^^
I have done a lot of blue ATF changes at 40k according to the MB maint sheet. some had 272/273 engs. mid year 13 is when they went to 70k services I believe.
'04 G55 '80 280GE '99 S420 '98 E320 2011 E350 2016 GLA250
My Interpretation of WIS implies the Anterior "Oval Indentions" with "Rear Beveled pan" indicates:
NAG2+ transmission (ie. "Blue" Fluid).
E-Class, SLK
Discussion Starter · #5 ·
Thanks konigstiger, vortecpwr & G-AMG, The engine is 272 but the tranny pan has oval indentations with beveled rear side.
The data card reads:
Gearbox: 722906 03 331991
Engine: 272980 31 885 108
Variant: A 272 010 64 98 85
Order base engine: A 272 010 85 98
Number for spare parts: 27298030
The pan says using the "blue" oil and I want to confirm with the serial number but I don't know what number I should read.:confused:
if your pan look like that than you have blue fluid.
if you have the 2 round indentions (placement as circled as above) than you have the red fluid. THIS IS HOW I determine what is what in some cars are work. makes getting parts faster out of parts depo.
E-Class, SLK
Discussion Starter · #7 ·
Thanks Vortecpwr, my local dealer confirmed red fluid.
E-Class, SLK
Discussion Starter · #8 · (Edited)
Color of Old Blue ATF
My local Mercedes dealer said the ATF of my 2011 E350 is red. Well, the color of old fluid looks more "greenish" black than "reddish" black (or burnt red) when I drained it today - I have not filled up with new fluid yet because don't know what type. The fluid is 38.5K miles and most of them are on highway. I changed the red ATF several times on other Mercedes models before but the colors were nothing close to what I saw from this vehicle. Now, I wonder if the dealer made a mistake when they confirmed that the ATF for my vehicle is red. The car was built in 04/2011 and the transmission pan is identical to the one G-AMG posted above with 2 deep round and 2 deep oval indentions (Part # A 222 270 05 12).
What is the color of your old blue ATF?
2011 E350
272 & 273 engine
722.9, up to transmission serial # 2 834526 (check data card) every 40,000 miles/4 years = ATF134 red ...
Now I'm confused. My '11 272, delivery date 3/3/11 has a transmission 722906 03 256254. Is that up to transmission serial # 2 834526 for the red fluid? Are the "2" and "03" preceding the last 6 numbers ignored? Also....from Konigstiger's post it seems that all 272 and 273 take red and all 276 and 278 (direct injection motors) take blue....or am I reading something into it that's not there?
E-Class, SLK
Discussion Starter · #11 ·
Thanks Konigstiger, your information about the pan is confirmed. I also poured a small amount of the old fluid in a clear glass and under the natural sun light, oh yes, it's blue... it could be a disaster if I let the dealer changing my ATF on that day.
1 - 11 of 11 Posts
