Since I pulled out my center console I decided I'd investigate my lack of footwell air. I got a MighyVac and disconnected the elbows on the solenoid switch and pulled a vacuum. Stations 7,6,5, and 4 held a vacuum (and I could hear the pods actuate for some - some pods would actuate just once). Station 3 didn't hold a vacuum. I pulled the pod out and tested it, and that held true. Stations 1 and 2 did not hold a vacuum. I pulled both of the recirculation vacuum pods and tested them outside the car. Both held a vacuum and actuated.
My logic is that my rubber elbows and tubing are bad, but perhaps I am doing the testing wrong for the recirculation pods. Both these pods seem to be interconnected. The vacuum line that powers the short-stroke pod also goes to the long-stroke pod. Is there a different way of testing these pods through the solenoid? Could my solenoid be bad? Any great difficulty in replacing the vacuum tubing? Also, since these pods are out I might as well get new ones. How difficult was it to switch the long bronze arm over to a different pod? Does anyone know the part number for the 3-way rubber connector? Does anyone know the part numbers for the vacuum tubing?
