Has anyone recently purchased a used S320?. Can you tell me what you paid and a little bit about the car and why you bought it? I am looking into purchasing a 1995 S320 and I need some encouragement to move on it.
Larry Rotondo
Larry Rotondo
I just do not think I need a V8. I would be driving mainly in town and the better gas mileage and hopefully lower maintenance are attractive.Why do you want the 6 cyl?
Thanks for your input. I am considering a one owner 95 S320 with 90,000 miles from a private seller who has all records. I think it should be worth less than $18. The wholesale is only $14.I recently bought a 96 S320V. Since this car is only used on weekends to drive, i prefered the Inline 6 over V8 or 12. Before i bought mine, i test drove several 420s and 500s. The bigger engines have their own benefits, but driving around in crowded chicago downtown, 6 or 8 feel the same. The tire size and engine design will be slightly different in the V8s. The longer and shorter 320 wheel base has only few inches different, and that does not change the cars overall massive look. Few of the problems i currently have is oil leak, and i have seen that in my friends S320 as well. The AC is also not working properly, sometimes it blows cold air, sometimes it dosent.
A 95 or 96 S320 in my area with approx. 70K + miles is between $20 - $27K range, depending on the condition and equipment. Try to get one with owner records.
Once you buy a car like this, ure basically going to spoil ureself. Its tight handling, suspension, swift braking and luxirious interior is not found in any other vehicle of its price range.
Greetingz,
///S320
Larry Rotondo
