Outstanding Contributor
450slc5.0cab 280sl5sp 280se4.5 500se+500slAMG +250seStkW108 350sl4spdX3 500secEuro
I know there are at least a few people who know recaro seats here. I am aware of several buttons, knobs and adjustments on mine:
- rocker switch on the side panel = power back tilt
- front blue button
- middle blue button
- back blue button
- two switch cutouts which were not used on mine
- lower side knobs on the back potion
- upper knob on only the left side = upper back tilt
- the part of the seat you can pull out to extend the seat, I guess for people with long femurs. That one is obvious.
See some pics of my seats here: http://www.benzworld.org/forums/r-c107-sl-slc-class/1599591-slc-convertible-4.html#post5265420
I can post more if it helps.
If anyone know what any of the above do or are called, I really appreciate your help. Thanks!
560SEC, 1988; 500SE, 1984; 500SL, 1983
If your seats are C's, then you have a heater switch, seat-back tilt switch, the air blower switch, and then the three blue buttons are to release the air from the three areas which inflate. Kinda cutting edge in the 80's...
Buttons and not all switch locations used:
Labels:
I know now that the knobs on each side move the side bolsters in an out. So that will be nice to squeeze them in a little tighter on my scrawny back.
I also understand the one upper knob tilts the upper back forward to accommodate my slouch.
Those two will be helpful adjustments.
Now if I can simply determine if I have air to determine if my blue buttons do anything at all.
More pics here: http://www.benzworld.org/forums/r-c107-sl-slc-class/1599591-slc-convertible-20.html#post5400189
