99-C43, 05-G55K, 71-280SL, 94-E320 CAB
Can anyone provide the thread size and pitch for the screws/bolts used on the six seat underside threaded insert mounting points ?
Ed A.
Tribute 500SEC AMG Widebody
6mm X 1.0 and 20mm long
and if you want to be absolutely exact allen head
Thanks Henric...
As always an answer can be quickly had on the W126 forum...
I'm designing the brackets to interface with the stock C124 power base.
This way I'll retain the fore/aft and up/down stock movement and switch.
May even bypass the back rest switch on the Recaro panel and use the stock door mounted control.
Ed A.
