1981 380SL
Folks, the blowby of engine oil to the air filter housing from the right side valve cover is significant. My last three-state road trip of almost 1500 miles required ten quarts of oil. My air filter is nearly saturated with oil. The car is a 1981 380SL.
The engine has a single timing chain replaced last year. The car has 130,000 miles on it. The car runs fine and I am getting 20-22 mpg with plenty of power. The car starts fine; I have replaced many of the J Ketronic fuel system parts.
However, I am willing to solve two issues, the oil blowby and the single timing chain, if I could replace the engine with a rebuilt long block. I have found two web sites that list rebuilt 380SL engines for sale, but know nothing about them.
My mechanic (non dealer) tells me that a complete engine rebuild (existing engine) would cost 5-8,000 dollars. That mirrors the cost of a long block rebuilt engine.
I plan to keep this car for the long haul. I would rather not start over with another car.
My question is: does anyone have good advice for purchasing a rebuilt engine? Is this done often or is the other approach of rebuilding the existing engine a better option?
Thank you.
Mike Gangwer
2017 Police Interceptor Utility, 2017 Police Interceptor Sedan
A reman long block is a reliable option. Many people do it.
Before you buy a new engine have someone check the back pressure on that engine a plugged exhaust can give the some problem. from someone who learned this the hard way
1981 Mercedes 380SL
I rebuilt my own for about $2800 in parts
the most ridiculous part was the pistons, they were $90 each. I did the transmission too and the mercedes-brand bands were $200 each (a $50 chevy part) There are plenty of aftermarket gasket sets, you have to be able to meausure what you have. I kept the exact same cams as they seemed unworn.
These motors are NOT something from another world, If you can rebuild a Chevy 350, or any modern motorcycle engine, you can rebuild one of these.
I got a donor 380sl motor to start with, magnaflux the block, and start building it up, replacing what is really needed.
just as I got everything perfect, I somehow lost my A/C refrigerant. so that is my current MB problem
