1982 300D, 1984 300TD-sold, & 1985 300D(parting/selling)-sold
Does anyone know if it is possible to rebuild the Engine Shock/Damper online they are 120$ each part number 1232414813.thanks
1984 300D
Use Of Flexane Urethene;Flexane (Urathane) made by Devcon
Cheap engine shock mounts fix
Cheap engine shock mounts fix - PeachParts Mercedes ShopForum
I suggested the Flexane the guy used. However, I had done a internet search there are people using some types of Urathene sealants to make Motor Mounts and so on.
One of the ones used was 3m Window-Weld Super Fast Urethane and there was another cheaper one that I cannot remember. For some reason it did not get into my notes.
Fixing a BMW Subframe Bushing
http://www.bimmernut.com/forum/5-series-bmw/23441-liquid-urethane-filled-subframe-bushings.html
Used to make a wheel
http://www.technogap.com/roadwheels.htm
The use of Flexane as a motor mount in post #8
http://www.mx6.com/forums/1g-mx6-general/65326-polyurethane-use-motor-mounts.html
