ML63 AMG & 2 350 SLK with AMG kit.
Turned on my rear wiper today and it will not turn of, it's killed it now, 4 hours on the motorway, I stopped and folded it out but it's just making noise now.
Is there a control module?
Vito 115cdi 2005
Mine did the same thing, I pulled the fuse to stop it, put it back the next day and it just continued running. Pulled the fuse again and forgot about it for a week, when I then put the fuse back it was ok. Been working ok ever since. One thing I must add is that it mostly doesn't return to the proper park position, you have to switch on and off till you get it to the right place. This was the case before the wiper started running by itself though.
I also have the problem that it will not stop at the proper park position when I use the wash function. When I use the normal mode, it seems to drag on the window. The wiper blade is new.
Could it be that it is too big a volt drop to the back of the van over the very thin wires?
