Ok, this is a wierd one. when i bought this car the drivers side window 'rear' window. worked. now it doesnt. I have tried the fuse's they are fine. i have listened for noises no noises/sounds of motors or anything. i have tried both switches and hit them many times up and down on the door and in center console any ideas????????????????????<br> <br>
Discussion Starter #2
Check the current at the switch then at the motor. Use a circuit tester. Connect to all wires at the switch and press th eswitch look for a wire which becomes live when you press it. DO the same with the motor.
