Does anyone have a photos of the motor/cable assembly? Something happened with one of the cables in the rear driver side window. The motor is fine. I could roll the window down but not up. I was able to pull the window up and it slides down by itself after some vibration. I took the door panel off and one of the cables (I assume cable that pulls window up) off and was just floating in there. I found where it belongs in behind the motor but I have no idea where the other goes. Its has a floating spring on it.
Any help would be appreciated.
500SE AMG, E350 4matic, GL 450
You probably would have better luck posting this in the w210 forum. Maybe do a search of that forum as well.
1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL, 2003 SLK320
Common problem. Regulator needs to be replaced. Part is under $100. In addition you need to buy the rivets to reinstall it. You need to drill out 3 or 4 rivets to get the old one out.
Actually if you go to the 210 Forum as suggested, there is a sticky in the DIY topics that covers the repair. I actually carry the procedure around in the trunk of my car along with a couple of 2 x 4 pieces that I have fabricated to hold the window up if it ever fails me on a trip somewhere.
Len
'99 E300TD 93,000 miles
