Can anyone shed some light??
When I push the rocker switch, it illuminates, then shuts off several minutes later as it should. However, the rear window does not defrost.
I have checked the grid in the window. It looks healthy.
I have found two leads that go to the window, one on each side of the window. What I don't understand is that they are both grounds. Where is the positive??
If I knew where the positive is, I could check it with a meter.
Where is the relay located. The Haynes manual does not locate it for me.
Anybody have any thoughs as to why it may not operate?
Thanks for your help!
