1989 560 EUROSEL 1984 190e8V 2000 e320 sport
my rear window blind will not go up on my 1989 560sel i know it has power there but it seems to be off trak any suggestions..
2012 CL550 4MATIC Coupe
When you say "Off Track" what do you mean? There is no "Track" There is a "Rope" (A nylon flex rod with one side being geared) that may be stripped and can be easily replaced. The motor pushes the rod up the guide "Pole" that goes up your window. The "Rope" goes up the rod and pushes that shade up with it via that little black plastic clip.
Can you post pics? You may need to remove it and replace the Rope. I bought a new rope for mine and it's sitting right here and I just got it from MB so I know they are still in stock. I paid $27.00 US.
I am getting ready to install mine this week and I will be replacing the "Rope" and doing a DIY on it.
if you could could you post some pics on how to do it i if it is a rope issue i would be happy if it is just that
what is the easiest way to get out the blind???
I have to run out now. I will post the info tonight.
ok cool
You have an SEL and I have not done the swap in my sedan yet. But the rear shelf needs to come out. I will have to look up the pob and post it.
