I remove the upper arm on my c36 to fit adjustable arm
for the wheel fitting side
MB use an insert (12mm) inside the arm with is 13mm longer to go fitted on the fuse and use a 10mm bolt
on the other side, a 12mm bolt
question :
why MB use an insert and after a 10mm and do not choose a 12mm bolt with partial thread
result will be the same ?
sure
that's my question
cause adjustable arm comes with insert
but insert are smaller : 43mm against 56mm
so I can not put it entirly in the arm
and I've got the feeling there's some play in the fuse hole
today I can hear some noise
so I like to remplace insert .... with a nice 12mm bolt partially threaded ;-)
