1 - 10 of 10 Posts
S500 | 220.175 | 113.960
Hello,
I took my shade down for the first time in several months and a day later it refuses to go up no matter what I do.
I'd like to check the fuse. From my understanding it is under rear seat. How is the fuse box accessed, how does the seat come up and which fuse am I looking for. Is one of those in the trunk a compatible spare for replacement?
Thank you.
W221 & Audio Moderator
2013 S550
Ive found the fuse chart, however no manual as to how to pull up the rear seat for access.... could some one please guide me in the right direction?
Thank you
2013 S550
You don't pull the seat up. You pop the bezel surrounding the courtesy light out - the fuses are there. The "manual" that discusses it is your Owner's Manual.
Hey I got to the relay, the reason sun shade didnt go up was due to the relay being half way out of its socket, causing it to be overheated. When I got to it, it was relatively hot compared to other relays next to it. Now im concerned if it should be replaced. I have 2 spare Hella fuses for the airmatic, would this me same one or something different that I need?
THank you.
Despite it being hot, it works ever since Ive put it back in its place.
1994 S420, 2001 S 500, 2010 s550
HI Guys I just purchased a 2001 S500 and the rear shade won't go down, I've checked the fuses all good, but I did find the relay "in the Q location on the fuse box" is missing. Would anyone have the number for it?
THank you.
Where is the relay located?
1 - 10 of 10 Posts
