1 - 18 of 18 Posts
2000 ML55 AMG
Are ML320 Rear Springs longer than/do they sit higher than ML55 Rear Springs?
I'm guessing the answer is yes, but just want to confirm.
Thanks,
Joe
w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Is this for sure? I seem to recall looking them up last year and the part numbers were all the same..
And where exactly did you look at these parts for their part #s showing them to be the same?
ML55 2003, ML55 2002, ML63 2007
We are not talking about fitting. Any W163 strut including ML55 is interchangeable between the models. But we are talking about ML55 Struts being different because of the lenght of the springs.
2002 ML55 AMG, 5.5 liters
Hello
New 2002 ML55 owner here in need of rear spring.
How do I tell the difference between the ml55 spring and the other MLs when buying
Thanks a lot 43sqd. I recently unknowingly replaced my broken 55 spring with a 320 it almost spoiled my new Blistein B6 performance shocks. The dust cover ripped off exposing the tube and it almost never absorb anything.
2003 ml500, 2004 ml350
In the states benz only sells the rear sping as a full package labeled rebuilt ( at least that is all I could find on a dealers web site.
1633201813 Is listed as a fit for almost all Mls' including 55, spring package
163320211380 Is listed as a 55 only spring package.
oem ML55 struts from the stealership are $$$. You can head into a pick n pull and try your luck there to find the correct ones, OR look at coil-over options (tested and proven + reasonable cost re-purposing the the ML oem top strut mount.) AND still provide you the correct ride height and ride for the ML55.
These are off an ML55 part-out we stripped last year (96kKm )
Screen Shot 2020-01-15 at 10.28.13 AM.png Screen Shot 2020-01-15 at 10.27.50 AM.png Screen Shot 2020-01-15 at 10.33.53 AM.png
View attachment 2617077 View attachment 2617078 View attachment 2617079
Do you still have these 55 springs? I badly need those
It will have a Pink tag along with 3 paint marks.
Just a follow up question: does the paint color important? The broken spring I removed form my 55 is marked with white, green and brown with no pink tag. When searching for replacement I saw some with the 3 paint marks but with different colors. Any clarity on this is greatly appreciated.
Supposedly the paint marks do mean a difference in the spring.
When I made my post above, I saw on a dealers site one Benz model that had 4 different springs/ color schemes.
But when replacing spring, struts. Shocks, tires they should always be replaced in pairs any way.
I do, the strut pair, (kept them as a spare for my daughter's ML430).
Have you looked at your local pick 'n pull or fleabay?
Better yet, BYO set of coil-overs. it's not expensive to build.
Can I buy your spare ml55 coil springs? I do have new Blistein B6 rear shocks paired with ML350 springs. The handling is terrible.
Also where I'm from ml55s are rare.
1 - 18 of 18 Posts
