1995 sl500 130k new throttle, upper harness, brake light switch, NSS
I am having asr abs light issues
several months ago they would come on when I hit a bump. Kill and restart and lights stayed off.
recently, the lights stay on at start up.
38 pin test pin #6 4 blinks. Open circuit rear left.
both rear sensors cleaned and ohm out at 1600 which seems fine. I have checked at both sides (under car and in cabin) of the multi pin connector by the fuel pump.
so far I have spent several evenings looking for cracked damaged wiring from the multi pin inside the cabin, through the rocker and under the dash but have not found a thing wrong or obvious.
I am trying to avoid buying a new used rear speed sensor if I don’t have to.
any ideas what the problem could be?
