Hi i have a 2015 sprinter chassis cab with box, the rear side lights are not working, everything else is working fine, please can someone help, i have checked fuses but also cannot find any diagram to show a fuse for this, thank you
REAR FLASHERS & BRAKE LIGHTS DON'T WORK. I noticed you commented on a previous thread where the rear flashers worked but not the front. I am having the opposite problem. The center rear brake light lights when depressing the brake. (not brake switch) the lateral (red) rear light illuminate when the lights are on. The lateral lights do not flash brighter / illuminate when the hazards are on, nor when I step on the brake, nor when the turn signals are activated. The front (amber) flasher work with turn signal and hazard lights. I tried to trace the wires best I could and can't seem to find a break. This unit is 2016 with 6000 miles very clean. I noticed this after the RV dealership replaced the front radio in the dash. Related?
