Can anyone give me step by step instructions for removing and replacing rear shocks on 1982 380 SL?<br>
I have new Bilstein shocks already just need to know how.<br>
<br>
Thanks much,<br>
Roman
Discussion Starter #2
<br> Shock Absorbers - Removal & Installation<br> <br> 1. Jack up the rear of the car and support the control arm.<br> 2. The upper mount of the rear shock absorber is accessible after removing the top, top flap, rear seat, back rest and the lining, then remove the cover plate.<br> 3. Remove the locknut and hex nut from the upper mount on the shock absorber.<br> 4. Remove the two hex bolts at the bottom of the shock absorber under the suspension arm and remove the shock absorber.<br> 5. Installation is the reverse of removal. Tighten the upper mounting nut to the end of the thread. (Make sure the car has sufficient clearance to withdraw the shock absorber).<br>
Rasputin,<br> <br> Thanks for the info on shocks. Just finised installation in about three hours. Saved me $150.<br> <br> Thanks much,<br> Roman
