1995 S320
prior to buying my '95 S320, someone replaced the original rear shocks/accumulators with cheap shocks. I need to replace the shocks, but don't know how to find a replacement part number. Any info/sources/part numbers?
1995 S320
to clarify, I'm not looking to put the original equipment in. The cost is too much. I'm looking to install standard shocks, but don't know which parts are the right fit.
93 190E 2.3, 94 E320 (sold), 01 E320, 99 S320, 18 Durango
I believe all S320 came with standard shocks and not accumulators.
'95 S600
I linked you the options. You either use Bilstein Touring or Sport, Meyle or Sachs shocks. Most people probably go with the Bilstein 24-017077 which are 3rd on that list.
You can cross reference the numbers on the Bilstein site if you want it.
Id say the LWB S320 would of came with self leveling (which he probably has if someone has removed it)
