82 380sl
Ive got an 82 380sl and im tryin to pull the rear rotors, but they arent coming off. I know this sounds pothetic. i have pulled the bolt in the center and taken off the calipers and banged on the damn rotor to no avail. Any ideas? thanks
00 S500,99 4wgn,87TD
The bolt in the center (13mm head) retains the axle into the hub. You must remove the 5m...
The bolt in the center (13mm head) retains the axle into the hub. You must remove the 5mm allen key (inbetween 2 of the lug bolt holes). Also be sure the emergency brake is released......
