1 - 11 of 11 Posts
2001 E55, 2002 ML55, 2002 SL500, 2001 996 Turbo
Going to replace my rear lock actuator and aside from the rivets and panel clips is there anything else I should replace while I'm in there and things are disassembled?
Gaskets, lube/grease anything?
Thanks!
1999 MTrash 430, its a joke
You should be covered. Just be carefull when removing the actuator to not bend/deform the run channel seal. Once its bent, its almost impossible to get straightened out.
Just wondering if there was a DIY on the rear actuator?
I was just going to use the DIY for the front one.
Thanks!
This should help. You don't need a rivet gun. I was thinking of the regulator.
I thought the rivets on the regulator needed to be removed in order to get to the actuator?
1 - 11 of 11 Posts
