Rear LED Turn Signal Not Working
10K views 6 replies 4 participants last post by  Jack Newsum
My 2008 C350 has an odd issue that's started recently with the rear passenger side LED turn signal. At least once a day it will decide to not work, which will give me an alert on the dash and cause the dash turn indicator to flash quickly. The turn signal will fail-over to the top non-LED bulb in the rear assembly and is flashing at a normal rate. Shutting off and restarting the car will sometimes correct it but other times it won't, and it will always return. I've had a mechanic look at it and he first thought it was a loose wire (which is the first thing I checked) but then was out of ideas after that. The intermittent nature of the problem flummoxed him; he said it should either work or not.
I looked through the forums and haven't seen this issue reported, so I'm wondering if anyone else has experienced this, and how they fixed it. I've been searching for the replacement light carrier, since the exterior plastic enclosure is in good shape and doesn't need replacement. So far I've not found the LED lamp assembly. Any insight is appreciated!
#7 ·
I have similar problem with 2012 E350 W212. Right rear LED lights work after first starting car (both turn signal and hazard flashers). No problem with right front, mirror or dash turn signal flasher. When turning on hazards, right rear will stop after 30 seconds or so. All others work fine. When turning on right turn blinker a second time, it doesn’t work. No error light shows on dash in either situation. Replaced rear tail light module, didn’t fix the issue. Help!
