Turns out that I have 1/16" vertical movement in the left rear hub of the SEC. Not good. I've torn the front end apart many times but never went into the rear hubs. Do I need to remove the axle? The manual (35-130) indicates the use of a "slot wrench" - what is that and is it really needed to get these apart/together??
The parking brake shoes are good and the disc brake rotor and pads look fine. Do I likely need only a set of rear bearings and grease seals??
Thanks,
Mike
Thanks,
Mike
