So I am having an issue... the lock on the rear hatch is not working at all... if I use the automatic lowering it will slam shut and then you can hear it keep pulling it. You can then just lift it by hand so I am guessing the electronic locking mechanism is shot... but even when it is fully open I will hit the red button and it might go up or just move up and down a bit... then sometimes it will work to close the hatch.
I complained about it in warranty but they said they couldn't replicate the problem and now 2 months out of warranty this is happening...
Anyone else had this issue? I guess there was a star bulletin on the lock itself...
Also anyone know of a good place for cheap OEM parts in the states?
Discussion Starter #2
I should ask as well whether anyone knows a good place to get the teardown cd's from? They are ridiculous through the dealers in Canada!!!
2008 ML320 CDI
2019 X350d, 2017 GLE500e, 2012 ML350BT (sold), 2013 A200 Exclusive(sold), 2009 ML350CDI(sold)
If you complained during warranty, and they "could not replicate" at the time, then I consider this is a warranty problem that they have failed to fix. :mad:
Make a good noise and I am sure they will fix it now. Hopefully they issued a service statement that recorded the problem, but even if not I would still pursue it.
2006 ML 350 (my first Benz)
I bought a used 2006 ML 350. Shortly after I got it, it started doing the same thing..intermittenely. Sometimes it would lock, some times it wouldnt. I would try it again, and it would eventually lock. About a month ago, it went out completley. It would just cycle and cycle, but not grab and lock. I had to tear into the lock, and disconnet the power to it. I tied down the hatch, and got it to the dealer. Price for the lock itself was $355, but I had found one on line for a little over $220. I challanged them on the price and they dropped it to $270.00 I was going to do it myself, as I had the old one 90% removed, but I had a few other issues I needed done at the delaership, so I let them do it. Parts and labor were about $510.00 It took 4 days, as these locks are not readily available.
