SL320, 300e, 450SL
At say 40mph or above as i let off the gas, my 300e immits a howling type noise. Any of you have this issue? My Chevy pickup makes a howl as well. My mechanic claims that after a rear diff change w/ Amsoil full synthetic, the noise/howl will practically go away? What have you experienced or done to correct this problem.[xx(][:0][xx(][:0][xx(][:0]
2002 CL55 AMG, 1993 190E 2.3L, 2004 SLK320 Sport
Check the diff. fluid level ! If it's low, add some oil and if it still makes noise it could be that the gears inside the diff. are gone ! By the way, did you check wheel bearings ! Definetly, a cheaper fix...
Banned
1992 W126 300 SE
The diff in my 300TE always whined a bit but the MB stealership said that it was common and unlikely to fail for a very long time.We had the car from 60-130k miles and it just stayed the same.I cured the problem whilst driving by increasing the volume of the stereo.
SL320, 300e, 450SL
Thanks Deathrattle!! Another excuse for me to go out and buy a stereo system for my car![:D].
