1 - 9 of 9 Posts
1983 300d turbo 249k (benzoil), 1983 300sd 188k, 1990 560sel 175k, 1985 380se 290k 1990 560sel
i was wondering if any one new if and what the difference of the gear ratios's on the rea end (diff) betwen an 83 300d and an 85 300d ?
'89 300E Turbo project, ‘85 Audi Coupe Quattro, ‘71 BMW turbo 2002, '73 BMW 2002tii, ‘67 Kaiser M725
1985 is 1:2.88
1983 is 1:3.07
1984 300CD, 1983 240TD Euro
From an old thread...
MTUpower said:
Here's the ratio's
R107
380SL,SLC RATIO 1:2.47
380SL,SLC,560SL RATIO 1:2.47 ABS
450SL,SLC RATIO 1:2.65
450SL,SLC RATIO 1:3.06
W116
280S,SE RATIO 1:3.69
300SD RATIO 1:3.07
450SE.SEL RATIO 1:3.06
450SE.SEL RATIO 1:2.65
W123
230,240D RATIO 1:3.69
280E RATIO 1:3.58
300D RATIO 1:3.46 This is the NA
300DT 85 RATIO 1:2.88 This is the turbo 85
300DT TO 84 RATIO 1:3.07 This is the turbo before 85
W126
300SD 85 RATIO 1:2.88 ABS
300SD TO 85 RATIO 1:3.07
300SDL RATIO 1:2.88 ABS
300SE,SEL RATIO 1:3.46
380,500 RATIO 1:2.47
380,500,560SEL RATIO 1:2.47 ABS
420SEL RATIO 1:2.47
W124
260E RATIO 1:3.27
300D 1987 RATIO 1:2.65
300E RATIO 1:3.07
http://www.benzworld.org/forums/w123-e-ce-d-cd-td-te-class/1193747-84-300cd-diff-gear-ratios.html?highlight=gear+ratios
Mercedes 300te
Just wondering if its worth it to keep the diif. for the '79 280e ?
so would it be a good idea to swap the diff from my wrecked 85 into my project 83 and what would it change? what is the good or bad ????????? economy ? speed?
Slower acceleration,higher top end speed but not all that significant.
1 - 9 of 9 Posts
