Both rear door electric windows don't work.
I checked for voltage at the switch in the rear door and all okay there so no problems with the front switches or kiddy lock.
Motor has continuity, 4ohm resistance. Removed two pins from the switch and put 12v directly to the motor and all I got was a bit of sparking. Reverse polarity and same issue.
The door I am working on has some water damage from a damaged window seal.
According to the manual you need to put the window all the way down to remove the motor assembly. Has anyone successfully done this without being able to wind the window down?
Cheers
Matt.
Cheers
Matt.
