1999 Black S320.. 278,000 and still pulling strong
hey guys just a couple quick questions if you dont mind. 1999 s320. how do you check the level of the oil in the rear diff and if it is low where do you add oil in? also what weight oil is recommended?
thanks guys
'01-E320 & 02-ST2
Check the knowledge base/stickies.
G-AMG covered it. You check it by unscrewing the fill plug, when full it should trickle out.
If you don't know when it was last done, then just change it. Any of the good synthetic gear oils are good, 85 or 75 W-90. Be sure to remove the fill plug first, before you remove the drain plug.
Good luck.
