2002 ml 55 amg
My rear console blower seems to be blowi g cold air when I have my temperature set to maximum heat. The front is fine blowing hot air but the back is cold air coming out.
Sent from my ELE-L04 using Tapatalk
02 ML320 06 ML500
You probably have a problem with the rear actuator motor.
Remove the panel under the instrument panel and look up and to the right and you will see the motors.
First warm the eng. to operating temp., then request heat and see if the rear motor lever moves. If not, tap the motor a couple of times with a wooden handle screwdriver and see if the lever moves.
If it doesn't, you must replace the motor.
