1988 Mercedes 500 sec
Rebuilding my rear ate 38mm brake calipers
When I ordered the rear rebuild kits they both hard same part numbers but different dust seals
Why are they different and which is better or the correct one
Pic 1 is a seal with a solid outer frame that clips onto caliper
2nd pic the seals are flimsy and soft and metal rings to keep them in place
Outstanding Contributor
350SDL, '17 GLS450, "Grandpa's Roadster" Project Car
The seal in pic 1 looks like a shaft seal. Dust seals usually have enough elasticity and "bellows" effect to accomodate piston movement. Can the one in pic 1 do that, or will the piston be exposed as the pad wears? I can't imagine that is right.
pic 1 is the seal that origionally came off the caliper its is pushed on with a tight fit and the centre does have movement ie folded rubber so piston can move in and out its outer section can best be described like that of a camshaft seal
