1 - 8 of 8 Posts
2009 ML350
Hey all. My wife has a 2009 ML350 4Matic and the rear brake light warning light kept coming on. I know many of us have had this problem and I realize there are a few fixes out there on the web but I wanted to add my 2 cents and hopefully save you more than that! I changed the bulb a couple of times and realized it wasn't a bulb issue. I removed the housing and there appeared to be a compromised or burnt area on the aluminum contact surface for the bulb. It is the small dark area in the photo in the shape of a spade.. I took a small piece of aluminum foil from the kitchen and wrapped it over the area, re-installed the bulb. Good as new and free of charge. I then put a little silicone over the joint where the lamp cover seats thinking perhaps some water had seeped in causing the damage. Just a theory. Anyhow, hope it helps.
For whatever reason, when I upload the photos, they are incorrectly rotated just FYI....
W163 Crash Test Driver
2008 ML350 (Me!), 2010 GLK350 (Wife), 2003 ML-350 (Deceased)
Couldn't you just sand that burnt spot with some Emory cloth until it's shiny again? Or is it a coating that is actually missing?
2009 ML350
I tried that cautiously but it appeared to further damage the aluminum coating. I could have been wrong but didn't want to risk it. Plus, if you have to sand quite a bit off, it may not contact the bulb as well when seated which caused the problem in the first place.
I think I would just sand the crap out of that spot until shiny. If it still didn't work you could always just cover it in foil. Oh wait... :D
Hey, what matters is it's fixed! Well done.
2015 ML250 Bluetec and 1987 560SL
I did the emery cloth thing on mine and it worked fine. The housing contact appears to be solid metal, so I don't think you can damage it that way.
I also don't think it's aluminum. When I had this problem on my 2001 E320 wagon, I soldered a piece of brass foil on it where the lamp contact touched, and it took solder readily - which aluminum won't.
2007 ML350, 2012 C250
So many people have had this problem, apparently a design issue, MB should do a recall.
2012 GL 450 4Matic
They did do a campaign and do have a fix. If you are under warranty or CPO the fix is free, the parts will run you about 20.00 per side and it is very easy to do yourself. I only had to do the left side in my car.
2009 ML350 164.186 / 272.967 / 722.9
Same issue, bulb was flickering. But in my case, the tab on the bulb holder was slightly corroded -- I just sanded it and pulled it up away from the plastic socket. Couldn't see any corrosion on the receiver in the car - awkward even with mirror, and contact point was under the bezel. Snugger squeeze fit after twisting in tight - works fine...great tout, thanks! Bulb was fine. Never got a code.
1 - 8 of 8 Posts
