1 - 12 of 12 Posts
1988 300CE Coupe German Import 1988 300CE Coupe Japanese Market Import
Swapping over the brakes and rotors on my wifes 300 CE (88) and I wont have a 12 point socket big enough to remove the axle flange nut so Ill have to go buy one and was wondering if someone out there knows the size to buy.
Thanks!
W124 Moderator
IIRC it is a 30mm 12 point. Leave the car in the ground when you go to loosen the nut and have a long cheater bar/pipe.
Sent from my XT1710-02 using Tapatalk
The manual says to take off the axle flange nut to get off the rear discs. I tried without the nut off to just hammer them a bit with a plastic dead blow to no avail. so I shouldnt have to remove the nut to get them off?
Bryce
W124 Moderator
Bryce
Slack off your parking brakes, remove pads etc, then remove caliper, then the rotor. Read the FSM in our DIY sticky.
1995 e320ce. 1993 230 TE. 1987 Kit car with 260e running gear.
Rear discs
Bryce
No Bryce you don't need to touch it for the task in hand.
As Jayare said, you need to find out/learn how to slacken the parking shoes.
w140 300SEL 1992, w124 500E 1991, w124 300td Turbo 1992, r129 500SL 1994
Hi,
I confirm that changing the rear brake disks or the pads, or even the parking brakes DOES NOT require the axle nut to be removed or even manipulated... at least regarding a w124. I tackled with that issues few days ago, and the nuts are there to keep the rear axle shaft plugged to the wheel hub, both rotating inside the wheel hub-carrier. Now, what do you call "rotor"?
I confirm also that on my s124, the nut is a 30mm 12 points.
Jean-Louis
W201 Moderator
89 190E2.6- 5-speed Manual, 95 E320 Sportsline-sold, 2001 E320 4matic Wagon-sold
Is this what you are trying to accomplish?
It is a very handy video for a first timer (like myself)
- Cheers!
Reading the first message, I would say "yes" but Bryce will confirm.
Changing the disks is not that difficult, you are right.
Usually, the little screw keeping the disk close to the wheel hub is by far too much screwed in... which is unecessary.
Apart from that irritating issue, almost no difficulty at all.
Jean-Louis
There is nothing in the video about setting the shoes. That vehicle was not ready for the road when it was lowered.
Or any indication to someone unsure, how to slacken the shoes.
The only sight of the adjuster is at 6.56 till 7.58.
W201 Moderator
It's coming from your side of the pond. You should take it up with them. These guys are generally very good with their videos though.
- Cheers!
1 - 12 of 12 Posts
