1 - 8 of 8 Posts
I was wondering about one thing:
Are there any of the dieselpumps on the w124 that can be used on another car
example:the pump from an 250D 10V on an 300D 24V
I have an 1993 W124 300D 24V Station wagon
Really hope someone here can help me with my question :D
Can't give you direct answer, but each engine is having its own design pump per my knowledge.
Than the same engines are mounted on different models.
You decided to withhold your location, so we can not use our database ;) but the same 3 liters diesel were mounted in late W124 as well as early W210.
Because MB sells different options at different locations.
For example we are way poorer in US, not having W210 with cdi engines available.
Than all our cars have build-in governors.
Than on West Coast I can not buy beer with more than 3.5% of alcohol.
okey =)
I live in norway so i think i can get my hand on just about everything over night from germany if i cant find it local :D
So i can pretty much use the pump from any OM606 engine? =)
Maybe not the turbo version that the w210 was delivered in
I know about a w210 3,2 diesel near me,ive had a quick look under the bonnet,and it looked like a OM606 engine..or maybe im way of?
That's a good question though, I'm not 100% sure. Just a quick way to start...I'd check the part number on your car and see if the numbers match. More than likely not, but good question.
I did own 3 liter non turbo and 3 liter turbo. Worked on both replacing darn fuel tubings. The injector pumps are identical outside, so I think they have different diameters inside only.
or different tension springs.
1 - 8 of 8 Posts
