1 - 20 of 23 Posts
2011 Mercedes E350, 1994 Mercedes E320
I have a 1994 E320 Sedan, I tried to read the check engine codes in the Engine compartment self diagnostic module. I turned the ignition to ON, without starting the car, and I pressed and held the button on the self diagnostic module hoping it would start flashing so I can read the stored codes, the module light didn't flash.
Is it supposed to flash? Is it possible for the home mechanic to self diagnose this car check engine light using the on board module?
Also, where can I find a list of the engine codes?
Mike
Start the engine and let it idle for a few seconds.
Depress the button for a couple of seconds, then watch the pattern of the light.
1 flash = all OK
5 flashes = EGR low flow (clogged tube usually, very common)
If you have more than 1 code, it will appear in this format: code, followed by a pause, next code, pause, etc.
W124 Moderator
86 190E 2.3L 16V, 95 320TE 02 S500
Welcome to the forum Mike. In short, the answer to your question is yes. Use the search tool of the forum and you'll find a rather large number of strings on this subject. Also, if you will, fill out your profile. It really helps all us, help you.
Good Luck,
Jayare
I'm fairly sure code 2 is indicative of a bad oxygen sensor. After replacement, clear codes by starting engine and holding down button for about 10 seconds.
Turn off engine and restart, check engine light should now be off.
W124 Moderator
hantour,
Here are the codes (all of them):
Emissions - Using Built-in Diagnostic Module
1 No Fault Found
2 Heated oxygen sensor faulty
3 Lambda control faulty
4 Air injection system faulty hot film mass air flow sensor with hot wire
5 Exhaust gas recirculation faulty
6 Idle speed control faulty
7 Ignition system faulty
8 Engine coolant temperature sensor open circuit
9 Intake air temperature sensor, open circuit
10 Voltage at mass air sensor too high/low
11 Tn-signal (rpm signal ) at engine control module faulty
12 Heated oxygen sensor heater circuit open or circuit short
15 Injector, cylinder 2
16 Closed throttle position information faulty
17 Data exchange malfunction between individual control module
18 Adjustable camshaft timing solenoid circuit open or circuit short
19 Injectors circuit open or circuit short emission control module adaptation in engine
control module at limit
20 Vehicle speed signal not present
21 Purge switchover valve circuit open or circuit short
22 Crankshaft position sensor signal faulty
23 Intake manifold pressure (in base module pressure sensor-) with engine running too
high/low.
24 Starter ring gear segments and /or crankshaft position sensor faulty
25 Knock sensors or engine control module faulty
26 Upshift delay faulty
27 Not used
28 Engine coolant temperature sensor (engine coolant temperature change monitor )
44 Not used
45 Fuel safety shut-off electronic accelerator or cruise control active
46 Resonance intake manifold switchover valve
47 Not used
48 Not used
49 Voltage supply at engine control module 8v
50 Engine control module
_________
PIN 8 ECU
1 No fault found
2 Engine Coolant temperature sensor
3 Intake air temperature sensor
4 Hot film mass air flow sensor
5 CTP switch
6 Not used
7 Not used
8 Idle speed control (ISC) system at upper or lower control stop or CC or EA indicates "limp
home" mode.
9 O2S 1 (before TWC) - voltage too high, circuit open or voltage implausible
10 O2S 2 (after TWC)voltage too high, circuit open or voltage implausible
11 O2S 1 heater (before TWC) - Current too high/low or short circuit.
12 O2S 2 heater (after TWC) - Current too high/low or short circuit.
13 O2S (Lambda) control system operating at rich or lean limit
14 Injector, cylinder 1
16 Injector, cylinder 3
17 Injector, cylinder 4
18 Injector, cylinder 5
19 Injector, cylinder 6
20 Self-adaptation at idle speed or upper/lower partial load at rich or lean limit
21 Ignition output 3 or ignition coil for cylinder 1 and 6
22 Ignition output 1 or ignition coil for cylinder 2 and 5 (Engine 111, cylinder 1 and 4)
23 Ignition output 2 or ignition coil for cylinder 3 and 4 (Engine 111, cylinder 2 and 3)
24 CKP sensor or magnet for position sensor not recognized
25 CMP sensor not recognized or implausible
26 Not used
27 TN-signal (rpm signal ) - open or short to ground
28 VSS - open circuit
29 Not used
30 Fuel pump relay module - open or short circuit
31 Not used
32 Knock sensors 1 and /or 2
33 Maximum retard setting on at least one cylinder has been reached or the ignition angle
deviation between the individual cylinders is greater than 6 degrees crankshaft angle
34 Knock control-output switch in engine control module faulty Momentary fault in
self-adaptation closed throttle speed/partial load
35 Model 124,129 and 140 AIR pump switchover valve and/or electromagnetic AIR pump
clutch. Model 202 AIR pump switchover valve and/or AIR relay module
36 Purge control valve - open/short to ground or B+
37 Upshift delay switchover valve
38 Adjustable camshaft timing solenoid - open/short to ground or B+
39 Exhaust gas recirculation switchover valve - open/short to ground or B+
40 Transmission overload protection switch - open/short to ground or B+ or open or closed or
implausible
41 CAN communication from engine control module faulty
42 CAN communication from ASR, EA/CC/ISC module or diagnostic module (OBD II) faulty
43 Starter signal (circuit 50) not present
44 Not used
45 Fuel safety shut-off of electronic accelerator or cruise control active
46 Resonance intake manifold switchover valve - open/short to ground or B+
48 O2S 2 (after TWC) heating circuit relay module - open/short to ground or B+
49 Voltage supply at engine control module implausible/low volts
50 Engine control module faulty or not coded.
____________
PIN 14 CC/ETA
1 No fault found
2 EA/CC/ISC control module (N4/1) or Safety contact switch (M16/1s1) or Stop lamp
switch or Cruise control switch or Actual value potentiometer or Starter lock-out/back-up
lamp switch or engine speed signal or vehicle speed signal or closed throttle position
switch or safety relay in EA/CC/ISC control module
3 Right EA/CC/ISC actuator (left cylinder bank) (M16/1)
4 Cruise control switch (S40)
5 Stop lamp switch (S9/1)
6 Starter lock-out/backup lamp switch
7 CAN data bus signal from EA/CC/ISC, ABS/ASR, HFM-SFI or LH-SFI (right or left)
control module faulty.
8 Left front axle vehicle speed sensor from ABS/ASR control module
9 Left rear axle vehicle speed sensor from ABS/ASR control module or in 124 chassis
Hall-effect speed sensor.
10 Engine speed signal (TN) from base module (LH-SFI) or engine control module (HFMSFI)
11 Closed throttle recognition signal to engine control module (HFM-SFI or Left LH-SFI)
Fuel safety shut-off to engine control module (HFM-SFI or left or right LH-SFI)
12 EA/CC/ISC control module voltage supply
13 Left EA/CC/ISC actuator (right cylinder bank) or actual value potentiometer (M16/4r1 or
M16/4r2) or actuator motor (M16/4m1)or magnetic clutch (M16/4k1).
14 Closed throttle position contact switch
15 CAN data exchange with ABS/ASR control module illogical
Replace your O2 sensor........
Good Luck,
Jayare
Uh, I think this is called hijacking a thread .. but here goes! :)
sbaert, you mentioned Code 5 for low-flow through EGR tube. I've replaced my EGR and the vacuum switching box and still got the code. I then ran compressed air into each tube at 90psi and it sounded fine but still get the code. The tube from the exhaust manifold to the EGR is for sure OK, is there really a problem in the flow through the other tube if compressed air got through?
Thanks!
If by clearing the codes you mean disconnecting the battery for 15 mins, yes. That's the only way I know to do that.
And no, I did not remove the EGR pipe to clean it, I only blew compressed air through it to see if it was blocked. I couldn't see where the other end attached - is it easily accessible to remove? Do you just run some brake cleaner through it once it's off?
Thanks for your help, I certainly wouldn't mind clearing my check engine light!
Removing the EGR pipe is a major PITA since it runs behind the head and then down below the rear of the intake manifold.
After my diesel experiment with Chrysler Combustion Chamber cleaner, I used a whole can (on a hot engine). Simple disconnect the pipe at the EGR valve, and spray in the CCC until it starts foaming out the pipe. Repeat until can is empty. Wait 30 minutes and reconnect pipe.
Haven't had any check engine lights since and much easier than R&R the pipe or using a speedo cable as a reamer.
2 wheel drive W163 and W124
I have the same car. 1994 E320 and when I held down the button the light only just came on and stayed lit up.
Did I do this right? I thought it was supposed to FLASH. Meaning the LED would just light up and then go out.
95 E320 Cabriolet, 140K
They should be near the button you push down on the unit next to the battery. They are electrical receptacles for the banana plugs described in the link I sent you. Yes, you'll need to make the $5 homemade reading tool to get the codes from Pins 8 and 14. The link I provided contains other links you should look through and get familiar with.
1994 Mercedes E320
Pressing the button on the 16 pin connector near the battery, I got 10 flashes, I believe this is MAF sensor, I have already replaced it. I do not get any other codes. Using a home made led tester I only get codes on socket 6 (3,4,8) check engine light is on and engine idle surges occasionally. Any suggestions?
1 - 20 of 23 Posts
