R129 sl320 '99 / W201 190E '90
Hi,
I have 1999sl320 and I don't know if yours is the same but - bulb type-
http://cgi.ebay.ie/ws/eBayISAPI.dll?VISuperSize&item=150510635005
Ba9 x 2 (4 Watt I think it says on the old bulb)- for two map lights - centre overhead
Using something plastic, pry down the plastic covering and you will have the bulb in its socket attached to the under-side of the plastic covering.
Push the glass part of the bulb back through socket and replace with the new bulb and clip it back into place.
regards
darragh
'96 SL500, Triple Black
Be careful while doing it the ear clips on the plastic clear lens break easily. If your car is cold, use a hair dryer and warm them up before removing, replacing, it might help a little.
2005 CLK500 black,2012 E350
success
Thanks--pushed left side of plastic cover- right side opened slightly-then got fingernail under right side and the cover sort of popped off.
