Gentlemen,
have another problem with my '2001 ML 320-Sport;,
following all the leads and procedures described within I have cleaned the MAF in my car, while the battery disconnected ALL TO MAKE the yellow warning light o go off,..... and the car was running PERFECT for about (highway) 1000 mi, then the CHECK ENGINE light came on again and the problems repeated themselves. I have recleanned the MAF, the new air filter was previously installed new, and... the engine is running very very bad.
Idle is unstable and when engine is cold the eng. stals, I've restarted the eng a number of times until I can put it in drive and go down the hill, when the engine warms up it runs perfect in higher rpm's but in low RPM's (idle to 1500) the idle is rough, not where it supposed to be. is there anything else I can fix myself and forgot about???
